Old 05-12-2004, 06:56 AM
ScottM ScottM is offline
Dieter Sprockets
Default Re: Loose center console
Brian,what is the difference between 5200 and 4200 and how permenant is it?
5200 is REALLY tough to remove once its set up. Both 4200 and 5200 can be used in similar applications, but in the case of your console where you may need to remove it in the future, 4200 is a better choice since it is "less permanent". For anything under water, I'd opt for 5200, but inside the boat, 4200 will suffice.
