Re: Loose center console
Scott nailed it on the 5200 vs. 4200 thing. [img]/images/graemlins/smile.gif[/img]
You said above that you have room to access the underside of your deck, right? So, drill the holes out and fill them with thickened epoxy. Then redrill and thru bolt the console and use large fender washers on the underside of the deck and lock nuts w/ the nylon inserts (seal each screw/bolt w/ 4200). Then run a bead of 4200 around the base to seal it off.
Brian
1981 Mako 17
