Old 05-13-2004, 08:35 PM
SC204 SC204 is offline
Default Re: Loose center console
Here's where I'm at,Ihave the console proped up and have looked at all the holes.About 90% are in tough shape.They got a little damp last sunday in the rain.I took a nail and bent over the tip and cut the head off and used it as a drill to scrape out the holes and under the deck.I have 2 aluminum plates 3" x7" to catch the back corners of the console as a backing plate.I need to cut in a circular access hatch in front of the console to get at the two front corners which will also have 2 plates put in.I have to wait for the holes to dry a little before filling them.then I will do all the 4200 stuff as needed.The problem is the T-top is mounted to the console only and not to the floor which creates a lot of stress on the console and the screws holding it down.
