Thread: Drying wet foam
Old 06-01-2004, 02:53 PM
JW-Tex JW-Tex is offline
Default Re: Drying wet foam
Perhaps you put two deck plates (one between each set of stringers) in the floor as far to the stern as possible and then remove the foam under the deck plates all the way to the hull. You can then jack the front of the boat up and the water will migrate to the lower area where the deck plates are...you can use dry towels and heat lamps to increase the wicking/diffusion of the moisture. You could also leave the deck plates out when the boat is not in use (assuming you store covered or inside).
I used a variety of techniques to dry an old wet Whaler...never again...
