Thread: sheared screws
Old 06-02-2004, 10:12 PM
FlytheCoop FlytheCoop is offline
Default Re: sheared screws
You can use a small drill bit and drill numerous holes around the screw until you can get it loose, push the drill to elongate the holes until they connect with the other holes and eventually you work the screw loose. Fill the holes with epoxy and move on.
