Old 06-18-2004, 10:21 PM
Bobby23 Bobby23 is offline
Default Re: Mercury outboard
pogden,
The armature is the wire in the core of the electric motor and the bedix is what engages the starter gear. There may be a problem with the starter or your engine might be locked up. If you take out the plugs you should be able to roll it. Hopefully the starter is bad. Good luck
