Re: trim / tilt issue
I'm running a 1996 150 Johnson Faststrike. Last year I lost the ability to tilt the engine up but still had the "down". Upon inspection under the shroud I found two solenoids on the top of the engine. I switched them around and the problem reversed itself. I spent the rest of the day rotating them to salvage a day on the water. They are fairly inexpensive and easy to replace. I don't recall if there was a "click" or not but it might be worth picking a couple up and putting them on to see if it fixes your problem. I carry two spares with me all the time now. I don't know the part numbers for them off hand but if you would like them I can check them out tonight.
Scot
Temerity => 1973 20' CC
Jitters => 13' Whaler
At Large on Lake Superior
