Old 06-28-2004, 03:59 PM
Default Re: Through hull placement
You need a scoop either through the bottom of your hull or on the transom mounted like a transducer that is mounted on the outside of the transom under the water line. Then you could run a line up the transom and into you tank through the transom. Through the hull is by far the best way to go but the other way would work but would look like crap.
FellowShip [img]/images/graemlins/crazy.gif[/img]
