Thread: Hot Wires????
Old 07-16-2004, 01:00 PM
Dave Hirshberg Dave Hirshberg is offline
Default Re: Hot Wires????
It may not be just your connection at the motor. If you have a battery switch in the system the bad connections could be there as well. If It looks green on the ends its best to cut back the cable a bit and put new terminals on.And, if the switch is old or origional its internal connections can deteriorate as well. You may need to replace it too. Frequent problem on older wiring.
