Thread: Wiring Panel
Old 08-13-2004, 12:54 PM
Default Re: Wiring Panel
I know you guys will come up with something, just keep the cost down. [img]/images/graemlins/grin.gif[/img]
Scott, your suggestion would work. The 8 switch/fuse panel will fit in that space. I was planning to get an additional VHF to mount in the cabin, so i could run a remote mic to the helm area. This would be fairly simple. Maybe not the best to reach through the wheel, but i could layout the switches with less use in the steering area and others more used outside of the wheel.
I need to get a new guage panel, so i should re-layout for additional switches/fuses anyway.
Here is a closer pic, i will take some measurements tonight;
Brian, when you mention fuse panel on the inside, do you mean "on" the hinged cover or "inside" the hinged cover?
If "on" could it be wired to still remove the hinged cover easily if needed to.
If "inside", would that defeat the purpose of easy access to check or replace fuses when needed.
Also, curious on using fuse panel versus push button breaker type. I was leaning towards push button breaker type.
Thanks guys .... [img]/images/graemlins/smile.gif[/img] - Nick
