Re: Wiring Panel
Here's my initial thoughts.
Ditch the fuel gauge and use the Navman to keep track of how much juice you have left. That will free up some space. Then move the hour meter to the bulkhead above the handheld. You don't need to be constantly staring at that anyway. Whala, more space. [img]/images/graemlins/smile.gif[/img]
Put the fuse panel inside the hinged compartment. You are right, it would take a bit more time to get too but it will be protected from the elements and curious little fingers. [img]/images/graemlins/smile.gif[/img] That will also keep wire runs short.
You should then have room on the right side of the panel for a minimum of 6 rockers or 9 toggle switches if you keep the gauges centered on the steering wheel. Maybe another 2 rockers or 3 toggles if you push the gauges as far to port as possible, while maintaining enough spacing between the port-most gauge and the edge of the panel so it doesn't look wierd.
You'll probably have to relocate the VHF mic mount though.
One of the best things I can recommend you do is cut a piece of cardboard to the same dimensions as the panel. Then cut a few circles the size of your gauges and a few more pieces the size of th switches you want to use. Sit down and play with them until you find a layout you are happy with.
I don't know much about breakers so I can't help you there. [img]/images/graemlins/frown.gif[/img]
Does any of that sound good?
Brian
1981 Mako 17
