Re: Hydraulic steering
Go to the teleflex website, click on seastar and look for the bleeding instructions. If you have a leak you have a problem I believe, but at least you can find out how to get the air out. As a minimum I would get a short piece of hose to slip over the bleed nipple and partially fill a small glass or cup with fresh fluid. Keep the hose in the fluid throughout the bleeding process and just watch the bubbles. When they disappear ( it may take 4 or 5 cycles) you should be done. Good Luck. Rich
