Thread: livewell issue
Old 09-05-2004, 05:38 PM
bj bj is offline
Default Re: livewell issue
The next time you are out check the well and see if it is empty before you begin running. Then check it while you are running and see if water is coming in thru the fill hose. If it is coming in then the cut off valve under the pump is open or not shutting off. You do have a cut off don't you? It may have been left off at the factory. If water is not coming in while running then check to see if it is comning in when off plane. This is the only time it could come in thru the overflow hose because while running it is impossible for water to come back thru it.
Have you seen the leaning post/livewell combo option on the 25'? That's what I wish I had. It looks like it would fit even in the 21'. Good luck. I hope you find your problem.
