Re: fiberglass layup schedule
Will,
I'm about in the same boat as you 78 MA [img]/images/graemlins/grin.gif[/img]
Just finished removing my old transom and grinding whats left of the old wood off(almost). Was considering using a different core than wood where did you order your foam?
I'm using 18 and 24 oz WR with RAKA epoxy. I was going to lay up a few layers of the glass on the old inner hull to build it up and then use three sheets of 1/2 inch foam sandwiched between layers of glass. at 0, 45 and 90 degree planes to one another. I'm sure others have did it other ways, hope that helps.
Pat [img]/images/graemlins/smile.gif[/img]
Worry less, Fish more!
