Re: not a seacraft but still a deep V
Ed, thanks for the kind words....like most everyone else on here, this boat stuff is addictive and I can't get enough of it. I don't think I would ever do an extensive project like this again though, it becomes necessary to employ other people and you begin to lose control of touching all the pieces yourself. the refit essentially took Nov '03 to June '04 and that doesn't include the interior stuff thats going on now...
The WW is now over 3 years old (since rebuild) and it gets used at lease 2 times a week. hours add up. It sits on the lift in the florida sun, it gets washed religously, but never waxed. I have cleaned the O2 sensors, decarbed 3 times, changed plugs 4 times, replaced a stator, and blew out one lower unit, probably because the fluid was contaminated when the plug wasn't screwed in all the way allowing water to intrude. (my own fault). Changed the batteries from group 24 to group 31s w/ higher ratings after 2 years, but still run with just two. The boat needs new leaning post cushions and one of the saddle tanks has a leak somewhere in the feed line which will require deck removal. Only other replacement done was a sw washdown pump that stopped this year.
