Old 10-06-2004, 01:13 PM
ScottM ScottM is offline
Dieter Sprockets
Default Re: Removing rub rail?
Chris,
I'm pretty sure your cap and hull should be screwed together independent of the rub rail. You'll be able to tell if there are more holes/screws under the rub rail when it is removed. I would seal the cap and hull with 3M 5200 before you replace the rub rail.
