Re: Removing rub rail?
My '72 23' CC had a semi-rigid 2-1/2" black plastic rub rail with a black insert. It was screwed in every 6" under the insert. After removing that, the deck cap was screwed every 6" with pan head screws and the bonding material was intact. I replaced the pan heads with countersunk flat heads. Then installed a new 2-1/2" black semi-rigid rub rail from Barbour Plastics screwed every 6" with a 1" stainless steel insert and that was screwed every 6". All the screws go into the deck cap. It was a lot of work, its strong and really made the hull look complete. -PF
