Old 11-09-2004, 05:39 PM
Default Re: Routing GPS/FF wire
Blizzard
Helpful hint
Start at the top of the T-Top tubing. Tie a 1/2 oz. egg sinker on one end of some rigging line and drop it down the tubing. Then take a piece of stiff wire like a coat hanger with a "hook bend" at the end. Stick it in the hole into the tubing and snag the line and pull it thru. Next tie the line to the end of your GPS/Transducer cable end. Using electrical tape, tape it securely around the end and the line forming a point. Sometimes a little silicon grease on the taped end allows it to be pulled thru the tubing easier!
BE SURE to pull an extra piece of line up thru with the cable to be used next time.
Are you totaly confused now
