Re: water inside hull
Peter, are you saying that water collects against the outside stringer? If thats the problem than you must have had the drain tube glassed over in a repair or that drain may be clogged. Each stringer should have a drain a couple inches forward of the transom to get that water down to your bilge pump [img]/images/graemlins/confused.gif[/img]
