Old 11-15-2004, 01:20 PM
ocuyler ocuyler is offline
Default Re: Trailer Question - spec and set up needed
John,
Here's an image of the SeaMark bracket from Hermco. Because the bracket is not on the same plane as the hull, I guess you could modify a trailer to extend the bunks and put a spacer in there, but I've never seen that. My sence is that the tounge weight would change after you intalled a bracket and the boat would have to be adjusted closer to the front. Interesting subject - any thoughts you guys?
Otto
