Old 12-04-2004, 08:18 PM
Default Re: Washdown system setup
Warthog,
Do you need a shutoff to shut the baitwell off when you are using the washdown, and vice versa??
Thanks!!
No you do not have to shut off the bait tank. You can run the two at the same time or independently. The inflow water supply to washdown pump is on the black part of the casing on the smaller of the two pumps pictured. It is actually below the pump so when you turn on your seacock it lets water to both washdown and bait tank pump. Hope this helps I'll try and get you some pics.
