Old 12-14-2004, 09:12 AM
Default Re: Closed cell foam
Although Whalers don’t sink they sure can get soggy. You might need to drill more wholes in other arrears of the boat where water might have accumulated to confirm you don’t have a bigger problem they you think. Would also make sure ALL cracks and holes are plugged up will first before re foaming. You might need to use a water sensor like they use for transoms down some of those holes to make sure all is OK. If you do have other spots of water inside the foam blistering could occur in the gel coat. That could cost at least a six pack just to get over your emotional reactions. Since they use that 2 part foam liquid through the boat when they build them I would just use that same stuff they use for foaming in tanks. Good luck
FellowShip [img]/images/graemlins/blush.gif[/img]
