  #59
Old 12-19-2004, 05:12 PM
Default Re: the end is near
Strick, how you making out with your boat? Ever find out where the list came from?
I've had her out 3 times. Still trying to get everything tweaked. Lots of little projects to finish before I can call it finished. I'm making a seat for the CC door right now. It's still raw and needs to be faired and painted but I have it bolted to the door. Also still need to put on some bottom paint. There is still a slight list however it's but not as bad as before. I think putting fuel on board helped some. I'm not going to worry about about it because the only time you see it is when you are out of the boat and looking for it! Cruises at 30mph 4100 RPM and WOT at 5100rpm 44mph. I have to look into getting a little more RPM out of her. The first two times out the engine wanted to give a little surge off and on that I mistaked for cavitation and now that wet away. I think I just needed to run the engine for a while to clean out the fuel lines and carbs. I had it out in 45mph winds on the other weekend so I tested the hard top and consel and they are rock solid. So I guess I'm happy. I'll post some pics soon.
