Re: That old topic...I am replacing my Tank
Good to see ya around !!!
Actually those tabs are up at the top of the tank ... When you get under the deck yours may be different
They had a 90 degree piece of aluminum along either side ...so you could fasten it as much as you wanted ...If you had room, tabs on the bottom might not be a bad idea
Wet foam killed my tank ...only down on the bottom 2-3" of the sides ...It held the water and corroded the tank (no coating). The three builders I have talked to (in NJ) either include or offer epoxy coating.
