Old 12-24-2004, 10:41 AM
Hooper Hooper is offline
Default Re: That old topic...I am replacing my Tank
1gal of partA and one gal of partB will give you 4cuft. That is if you don't do it in cold weather. In cold weather it will not expand correctly. In warm weather you need everything set up where your going to do your pouring. You pour part A in with part B in small measured quanities and stir for about 45sec. You better be pouring it then. Ideally you will have "L" brackets welded to the side of the tank to lag bolt it to the stringers too.
Thanks Warthog, just so I am clear, you're talking about the foaming process right, not coal taring right?....
