Thread: Fuel tank
Old 02-01-2005, 09:41 PM
Runco Runco is offline
Default Re: Fuel tank
The flange on the deck did need to be trimmed back about 1/4" to 3/8" on both sides to make room to pull the tank out. There were two side brackets with long screws that went into the stringers. I cut those brackets the same time I was trimming the flange, they came right off with a good sabre saw. The flange still has about 1/4" to the hold down holes so there is still plenty of support. I then took a saw I bought at Lowes, looks kind of like a pruning saw and really sharp and cut between the foam and the tank all the way back and forth the length of the tank. I then took a piece of 3/8" nylon line and fed it thru the sending unit hole and out the fill tube and tied it off. We have a fork lift truck which I used to pull the tank stright up and out of the boat with a couple of friends guiding it out. Of course the tank was empty and clean of all fuel. The tank was 99" long by 28" wide and 10" deep for a total gal of around 144. I am putting a new tank in that is 96"x28"x10" for a total of around 110 gal. The area that the tank sits in was in perfect shape, fully fiberglassed and no rot. The toughest part was cutting away the foam from the sides of the tank but it took only about two hours from start to finish. Any other questions to help let me know. I would have responded earlier but have been away for a week.
