Re: Deck drains on 20's
My '79 MA, mfg in Sept 78, has drains out the transom. A buddy's '78 MA (mfg May 78)told me his drains out the bottom. You mentioned that a 1980 MA had the drain in the bottom of the hull. I don't know what to make of that. Perhaps the transom drain was not well received and they went back to a bottom drain configuration??
BTW, the transom drain is horrible unless you use ball scuppers. Every time you stop water will rush into the boat from the back pressure.
