Re: Hull Changes
The more you cut from the rear, the greater the transom deadrise becomes. So you probably won't get more draft and you'll have a boat that rocks easily. I suspect Grandpa will be turning in his grave if you try this.
To get a few more inches of draft consider replacing the probably waterlogged floor, transom and stringer foam. Then get the smallest lightest two stroke that will push that thing.
