Re: 18 repowering ideas
I have a 1985 seacraft SF18 with a 87 115 merc and a 25" orig tansom. Turning a 17 inch pitch prop, top speed is around 38. cruise is around 27/28 mph. the motor wgt. is 316 lbs. The 115 is in excellant cond. but I want to repower to gain some mph. I've looked at the four strokers also and found them to be alot heavier and slower than the 2 strokers. I think a 140 sukie is in the 500 lb.which could be a bit on the heavy side for an 18 which was rated for a 150 before 4 strokers were around, but as someone said you can plug your drains and be ok. I'm presently looking at a 150 merc 2 stroke which weighs in at 415 lbs. Turning a 19 inch pitch prop the speed should be near 48 or 49 mph I think. Anybody running a 150 merc on an 18SF with some numbers? and can you raise the motor some on the transom? Butch
1985 seacraft SF18 with 97 merc 150 EFI
1988 shadow bass with 200 Johnson GT
74 searay 240V with modified 351 Ford/Mercruiser.
One is not enough!
