Re: Anyone ride a Harley?
Veso, if you want to wait on buying a lowering kit. You may be able to slide your fork tubes up through your trees by an inch or so and acheave the same seat height . This will shorten your wheel base a little but the bike will still handle fine. Be carefull you have clearance to your tank when the front is turned side to side. Measure the tubes with a scale or good ruler and keep them even. This is an old ice racer trick. Scotty.
FXRSCOTTY
