Fishman,
Welcome to the site. Do you have any images?
the transom is kinda wrapped in aluminum- I don't know if this was a band aid patch, or the person that re-gelcoated the outside of the hull(which was not the current seller) fixed the transom and didnt want it to rot again. The transom doesnt seem to flex, and I can't see any stress cracks where the metal ends. Any way of looking for transom rot other than ripping the back off?
I would be conserned about any boat described as "being wrapped in aluminum". There should be NO METAL involved in a transom except nuts and bolts. Your consern should be that you are buying a boat that requires a transom rebuild that will set you back many weeks and many hundreds of dollars. Assume nothing and make sure what your getting. If you are not confident, stall the deal and have it surveyed by a professional.
A bracket is the ultimate upgrade for the 23. You really want a Hermco flotation bracket. However, with that motor, the original set up is great. Consider the bracket for an upgrade to a 4 stroke or twins.
Best of luck with your choices.
