Re: 21' 1962 restoration
allright, so shes pretty much gutted! now for the questions
1. since i need to replace all the stringers, should i do them one at a time (take one out and replace it) or rip em all out and do em all. trayder id like you to respond to this one cause i believe you took yours out completly.
2. i plan on raising the deck 2-3 inches, thus making the stringers 2-3 inches taller, the outer most ones will not be a problem because the glass is still intact so i can copy the shape and add the inces to the top. however, the inner ones are way to far gone and they will have to be made from scracth, so what is the trick to insuring they will sit properly and the deck will be level.
3. can you guys measure your consoles for me, LxWxH, and lemme know what looks good, and yes i am a fan of bigger consoles
4. fuel tanks - i looked at some today at a savalge place and can get them for 3 dollars a gallon, they had an 80, 100, and 134 gallon, the 100 and 134 would be really tricky to fit in, so will 80 gallons be enough? (i would love to get away with only $240 on a fuel tank
Thats all for now!
Ben
no falls, no balls
