Old 04-22-2005, 07:02 AM
RS RS is offline
Default Re: Drill oversize holes- fill with epoxy - how
I'd whet out the inside first with unthickened epoxy using anyting handy (q-tip, small brush, etc.)
Then use a meat infusor to inject the cabosil mix from the back of the hole forward, withdrawing the needle as you finish injecting. The infusor looks like a big hypodermic syringe with a plastic needle. They are about $4 at X-marts.
Tape over the hole until it first sets. You can use a putty knife to scrape it level while it's a little soft.
Best regards,
Roger
http://members.cox.net/rhstg44/Misc/...go%20small.jpg
1979, 20' Master Angler
