Old 05-01-2005, 07:02 AM
Sleeto Sleeto is offline
Default Fastening leaning post
I am installing a new leaning post with circular bases. I can thru bolt the screws on the inside half of each base, but I cannot reach underneath to bolt the outside half because they are on the other side of (or over) the stringers. I assume I will have to use some type of self tapping screw. Is this correct way to do this?
What kind sealant should I use? If I were to use 5200, will I be able to remove the screws if need be?
Thanks
Paul, 1989 23' SC CC 250 hp Suzuki Four Stroke on Stainless Marine bracket
