Re: Fastening leaning post
There are toggle bolts that you can use for the areas where you can't reach the underside of the deck. You should be fine using 4200 to seal the area, especially since it's above the waterline and doesn't involve a thru-hull fitting. That way you can remove the screws if need be without killing yourself on 5200.
