Old 06-16-2005, 11:07 AM
stevebrownell stevebrownell is offline
Default Re: Need help with a late 60's 20 cc I/O
I'm planning on installing a new tank below deck this winter, increase the capacit a bit, but more so to install a modified console (narrower) in my 20 i/o. I think moving the tank from above deck to below would serve two purposes: lower the center a gravity a bit, and more important, free up some space. One does have to cut a perfectly good deck to do this though....
It's doable, considering some of the other projects board members have done here. You can also rest knowing that your tank is clean and shiny-new, and replumb your fuel fittings and sender. Not a bad time to inspect and work on the foward bilge and check stringers and other items.
By the way, any pics? where do you hail from? I'm on the south shore of Massachusetts, and would be interesting in comparing notes with any other 20 I/O owner out there. I think that model is one of the best looking boats in the fleet.
19XX? 20' I/O
