Re: Floatation Bracket...Build or Buy?
Captn C You did great on the drawing. If it was mine the transom core would come to the bottom. Actually you would grind a slight radius on the outside of the core corners. This is to account for the fillet that you would run around the bottom and up the corners of the transom.
When doing as mush glass work as your talking about here, I'd pull those thru hull's and fill the holes. Then redrill them up higher with one in front of the other. Keep them as high as you can. [img]/images/graemlins/grin.gif[/img]
