Re: Thru Hulls for biatwell...
Ha John
I re did my live well and set it up like the newer 23 CC with the live well just behind the leaning post seat. I made a 34 gal live well on a platform the same height as the gas tank. I have a scoop going through the bottom of the hull where the original scoop was I believe ¾” diameter then to a cut off valve and then to a 500 gal pump the hose enters the tank approx 2/3 of the way up the tank I have a bottom drain with a cut off valve and a large drain line approx 5” from the top of the tank that drains out the transom close to the bottom of the transom this set up works great for me. I installed a variable timing on/off switch that controls the amount of time the pump stays on. I found that fresh salt water coming in and going out at 500 gph works much better that a re circulating system. Can keep 200 bait nice and alive with no problems this way.
FellowShip [img]/images/graemlins/wink.gif[/img]
