Re: Stress Fractures
If you plan to paint the deck, you can use Dura Glass.
Then use Awl grip Hi Build primer 545. It will hide all of the stress cracks you have. Depending on how bad the cracks are you might be able to get away with a meddium build primer. When I replaced the deck in my 70, I gave it a light splatter coat which hides every thing. Just keep a light color what ever you do. The darker the color the hotter it is under your feet. Good Luck.---- Ken
