Re: More Wiring Help
you can find the right size and colors for the wire you will need for each componant in the book (BW and west also have in their catalogs) . My best tip would be that you draw it all out and make yourself a diaghram of what you want to do prior to starting the actual job. That way you will know where you might need and extra ground terminal or power terminal strips. (this will save you time, buku money on wire you dont need and help you with a routing plan so all of your runs will be "neat". good luck- not as hard as it looks- craig
