Thread: Seafari Stern
  #52
Old 11-15-2005, 11:35 AM
JW-Tex JW-Tex is offline
Default Re: Nick / others- interesting alternative -
What about using one of the hydraulic jack plates with the built in setback...would that allow you to make the transom higher? I know most outboards you can adjust the tilt limiter so as long as you can achieve all of your trim settings you could limit the tilt so that it does not hit the transom and then use the jack plate to raise the motor to provide clearance. Addtionally you have potential performance enhancements avaialbe by using the jack plate.
Moesly 1969 20 CC & Potter 1978 23 CC (23 in storage awaiting rebuild)
