Re: Thru bolt hull to top - advice wanted
I removed the top cap,re-glassed the inner gunnel(hull) all the way around.Cleaned all the outside & inside top caps screw holes. I re-placed the top cap(Make Sure its aligned/even) pre-drilled new screw holes every 12-14"s or so.Screwed them togther then between them I thru bolted with longer bolts. This gave Me a place to put the Tie wraps w/ holes in them for the wires.I used 4200 on the in/bottom gap then put the rub rail back on. Sealed under it w/ Quick drying 4200/5200(No Drip)?I can still remove for any reason w/a lil' more work. It's solid now.What a differenc in quietness too!
Scream'n reels'
Tug [img]/images/graemlins/cool.gif[/img]
