Re: What the ...?
I'm not an outboard mechanic but I would look under the cowling to be sure the engine oil resivoir is not leaking,if not then I would think the lower unit seals would be the next obvious culprit. The mechanic I use allways checks for fishing line behind the prop when doing a motor service,apparently it can eat up the prop shaft seal.
[img]/images/graemlins/ooo.gif[/img]
