Old 02-10-2006, 09:36 PM
abl1111 abl1111 is offline
Default Re: Whitewater advice and suggestions.
A buddy of mine had a similar problem on his 23' Chris Craft Lancer. For his application, he took several pcs of 1/4" plywood, laminated them together and glassed it widthwise - attaching to the ceiling and the sides of the hull ( which might be a problem because you probably have a a liner - which won't let you tab directly to the hull ).
Hardest part was making a perfect fit of this support - but once done, he just stenciled it to the rest of the 1/4" plywood - cut, laminated and then glassed in place.
