Old 02-17-2006, 02:27 PM
warthog5 warthog5 is offline
Default Re: Hull to deck joint.?.....again..
Any opinions on the glue reacting with and epoxy/cabosil mixture?
I hope you not going to do the fairing with epoxy/Cabisol.
If you do you will find out real quick that you will be sanding your ass off.
Also when mixing epoxy and adding cabisol or microballon's in it you will find that in the mixing process will induce air into it. This will leave you with small pinhole's all over the surface. That mean's wiping in the surface again and again.
Id suggest that you buy System 3's Quik Fair. It's ready to go and you mix it at a 7 to 3 ratio. I use a digital gram's scale. It is packed under vacuum to remove any air. You fold the 2 part's over on itself, like you would mix Bondo.
It can be sanded after 4hrs unstead of having to wait 24hrs.
Hamiliton Marine has the best price on it. You will be money and time way ahead of the game by using it.
