Old 02-18-2006, 02:30 PM
Default Re: Sliding cooler seat removal
The cooler seat also has a metal slide that is screwed into the bottom of it which connects to the metal sleeve that is screwed to the deck. Access to those screws can only be reached if the cooler was upside down. Therefore, It should slide out.
You might want to check with forum member "Luis" as he just removed his off his 20'.
