  #31
Old 02-20-2006, 11:00 PM
Fishjack Fishjack is offline
Default Re: Yet Another Transom Job in the Works - ?ions
More Pics of "I guess" progress -
Scott - I will have to dig around to see what is in there? Not sure yet will advise.
Warthog - I like the idea of a thru-hull X-ducer.. How do they perform at speed?
Cut further down towards the bottom of the hull - you can see that one of the old 1" brass drains had a crack in it -
Can anyone say core trouble? I knew I had some soft spots on the cap.. I will tackle this project later.
Cut out the Ice boxes - Below I scraped some of the foam that is in the inside corners. Water is standing in a recess under the deck just to the right of the exposed foam.
You can reach your hand in there and feel it. The starboard side is dry as a bone. Is there some sort of drain that might be clogged???
Here is a little cleaner shot of the factory thru-hull transducer??
Also a lot of other transom jobs I have seen pics of have two stringers instead of the single stringer in the center that my boat has?
It is a B**ch getting that wood out of the bottom of the transom..
Another question - the inner skin (which is all I have left) is very thin. Should I just cut that out or try and bond my new plywood to it??
Thanks for the responses.. Jack
"Anything you let a dog do, you're training it to do." -
1977 23' Superfish
ST250x Yam
