Re: stringer problem
Hayden - this is going to boil down to you, asking yourself how handy, and adventurous, you are.
There are a ton of folks here who have tackled this scene successfully - check out the pix - trayders 20 will probably give you a direct, blow by blow pictorial.
fiberglass is actually pretty easy to work with - this isn't rocket science, just preparation, diligence, and willingness to do a job right.
Taking out a foamed in gas tank has also been addressed and discussed at length, along with the merits of the foam, and whether or not to foam it when putting it back in.
I can only heartily recommend doing a bunch of topic searches. I'll also suggest that there are many projects over on the classic mako forum worth studying, as well.
But the simple answer is, Yes, you can do it successfully, if you think you can.
Bill
