Old 02-23-2006, 01:19 PM
Finster Finster is offline
Default Re: Decarbonizing 1999 Johnson 175 Carb.
unscrew the brass plug on each carb to drain all the fuel out as well.
I'm not a big fan of draining the carbs. They have a tendency to varnish up when empty.
I've found the best way to store a motor is: fill the fuel tank so condensation doesn't accumulate in the tank, add stabilizer to it and run it to get the stabilizer into the motor. Take your engine store shoot it in each carb (while running the motor), The pop all the plugs and shoot it in each cylinder.
Drain your lower unit to make sure there is no residual water that can freeze and crack it.
And your good to go.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
