Old 02-25-2006, 06:13 PM
Scott Scott is offline
Default Re: Trim Tabs on a 23' SF with 250 hp Suzie?
Capt Scott
Those are the tabs Tabman, from Bennett TrimTabs is recommending for the 23's (M120). With their design they give the same lift as a 12x12 tab ... there is not as much slip with the "wings". The wings channel the water so it doesnt slide out and off the sides. Plus I think?? you get a better control switch with the M120.
You will need longer hydraulic lines to get to the console, I did. I would drop an email to Tabman .. he might be able to help you out with that
I was back and forth with the tabs … Tom convinced me that the M120 was the one to go with. Also if a bracket is in your future the actuator will fit under one better … Sounds like same “throw” but a shorter cylinder.
